Inventor Forum
Changes to derived parts in 2013?
8 REPLIES 8
Message 1 of 9
ad64
1130 Views, 8 Replies
Most of my part files contain at least one sketch which is derived from another part file. These derived sketches do not update like they did in our previous versions of Inventor.
If you change the geometry on a sketch in the base component, the updates will flow through to the derived parts. If you add geometry, it also works. However, if you delete any geometry from the sketch in the base part, it will not be deleted in the derived sketches in the second, third, etc. parts. The 'deleted' sketch geometry remains in those parts until you go into all the parts which derive from the base part and manually delete it. This is a significant problem for for our workflow.
Has anyone else noticed this? Is there an option I have missed that changes this behavior so that deleted geometry in a sketch will also be deleted in any derived sketches in other parts?
Steve
Inventor 2013
8 REPLIES 8
Message 2 of 9
falkmassmann
in reply to: ad64
Do you see this behaviour if you update the derived part, incase there is an update pending which I think it should since the base part changed.
What happens if you recreate the whole derived part with the funtion on the management menu?
Should be something like "recreate all", I have german interface.
Cheers Falk
P.S.: Did you migrate your files and do you see the same behaviour with genuine 2013 files?
Message 3 of 9
in reply to: ad64
I have seen the same behavior in 2013.  Already uninstalled so I thought maybe it had always been that way and I just forgot, but maybe it is a change.
Message 4 of 9
ad64
in reply to: falkmassmann
This behavior is seen even after the part has been refreshed / updated. These files were created in Inventor 2013 and have not been migrated from an earlier release.
This consistently happens when the sketch contains a block. Sometimes it is impossible to delete the geometry because it no longer exists in the original part and "Edit block" is greyed out in the derived part.
Message 5 of 9
Yijiang.Cai
in reply to: ad64
I could reproduce this behavior in R2013 RTM, but not reproducible on R2013 SP1 internal build.
River Cai
Inventor Quality Assurance Team
Autodesk, Inc.
Email: River-Yijiang.Cai@autodesk.com
Message 6 of 9
ad64
in reply to: Yijiang.Cai
I appreciate you looking into this, Yijang. Did you test it both with deriving a sketch and with deriving a block only? I most notice the problem when deriving a block only. The geometry gets left in the derived part even after it is removed from the base part and there is no way to delete it.
Will the service pack that fixes this be released soon?
Message 7 of 9
Yijiang.Cai
in reply to: ad64
Hi Steve,
I have experienced all the cases that you talked below, and it really works fine in internal R2013 SP1 build. For the SP1 release, there will be one SP1 beta release in the coming days.
River
River Cai
Autodesk, Inc.
Message 8 of 9
I am experiencing this same behaviour in Inventor 2014 SP1 Update 3. This is going to be an problem with the workflow we are attempting to use. Did this issue get fixed in 2013 and then reappear in 2014?
I have a large array of points imported from an excel spreadsheet with XY co-ordinates. This is imported into a sketch. The sketch is then derived into about four different parts in the assembly that use the same locations. Removing points from the sketch does not affect the parts that the sketch was derived in to. The deleted points remain.
Dave
Message 9 of 9
Yijiang.Cai
It is really interesting that this is not reproducible for me. So could you attach the dataset or send it to me @ river-yijiang.cai@autodesk.com?
River Cai
Autodesk, Inc.
