Inventor General Discussion
Valued Contributor
DanSingleton
Message 1 of 2 (136 Views)
Change how Parameters work
136 Views, 1 Replies
10-17-2013 09:35 AM
I can't be the only one this drives nuts... Why can't the parameter system work simply and correctly without having to jump through hoops trying to get units to convert correctly?
Here's a pretty simple example:
Dist = 18.773015 in
Adder = 3.000000 in
Len_Suggested = ceil(Dist + Adder) = 22.047244 in
Uh no... that should be 22.000000 in
Anyhow, to get it to work correctly you have to use:
Len_Suggested = ceil(DIST_HYP / 1 in + LEAD_ADDER / 1 in) * 1 in = 22.000000
Who in the world, by choice, would actually want to write formulas that require you to multiply stuff by 1 in and divide by 1 ul to get the correct answer? How does this make my life easier, Autodesk?
Treat parameter values as simple integers and real numbers during calculation and get rid of all the units junk except for display purposes. That's what almost every other application does (including existing iLogic functions)
Grrr.
Distinguished Mentor
ccarreiras
Message 2 of 2 (119 Views)
Re: Change how Parameters work
10-17-2013 10:26 AM in reply to: DanSingleton
Hi!
I Agree with you, sometimes can be painful.
This is how i use to do. It´s another way to solve the same issue.
Maybe you already know the process, or maybe not... Check it
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
Regards.
CarlosC
Autodesk Inventor 2014 Certified Professional
Autodesk Factory Design Suite Ultimate 2015
Windows 7 64Bit
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
