Inventor Forum
Change a tapped hole from through to blind using iLogic?
3 REPLIES 3
351 Views, 3 Replies
Does anyone know how to change a tapped hole from being tapped through (tapped through hole) to being a tapped blind hole with dimensions for the tap drill depth and thread depth using iLogic or A.P.I.?
I would like to be able to switch back and forth between the two different types of tapped holes (through & blind), per whatever is required by the iLogic .ipt that is generated by user inputs.
Does this make sense to anyone?
3 REPLIES 3
mdavis22569
Probably get a quicker answer going over at the Customizing board about this ...sure someone can answer it quickly there.
Mike Davis
in reply to: mdavis22569
I've placed the question there as well, thank you.
