Inventor General Discussion
Valued Mentor
jeanchile
Message 1 of 8 (1,386 Views)
Change a Read Only CC file to Read/Write?
1386 Views, 7 Replies
09-06-2011 06:38 AM
Hello all,
I created a custom content center library a while back using 2010. I need to edit members in that file but now my custom content center file is listed as read only and I can't seem to change it. I'm not sure how it changed but I am assuming my upgrade to 2011 a long while back created this issue.
How do I get the read/write capability back?
Inventor Professional 2013 (SP-2.3), Product Design Suite Ultimate
Desktop: Intel Core i7 3.4GHz, 16.0 GB RAM, Windows 7 Ultimate SP-1, 64-bit OS, (2) GeForce GTX 580 (331.81), Space Pilot Pro (3.16.1)
Laptop: Intel Core i7 3.9GHz, 16.0 GB RAM, Windows 7 Pro SP-1, 64-bit OS, GeForce GTX 780 (331.81), SpaceNavigator (3.17.7)
MariaManuela
Message 2 of 8 (1,376 Views)
Re: Change a Read Only CC file to Read/Write?
09-06-2011 07:10 AM in reply to: jeanchile
Its a Server or Desktop library?
You already try in Server Console?
From computer's Start menu Select Programs > Autodesk > Autodesk Data Management > Autodesk ADMS Console
Maria Manuela Pinho
Application Specialist
Cadtech / Asidek - Autodesk Gold Partner
Autodesk Inventor Professional 2015 | Lenovo W520
Valued Mentor
jeanchile
Message 3 of 8 (1,355 Views)
09-06-2011 08:44 AM in reply to: MariaManuela
I apologize, I should have addressed this in the OP. It's a desktop library, I am not using ADMS or Vault.
Product Support
alessandro.gasso
Message 4 of 8 (1,341 Views)
09-06-2011 09:10 AM in reply to: jeanchile
Did you migrate the custom library correctly from R2010 to R2011 following the steps you can see in the post below?
http://forums.autodesk.com/t5/Autodesk-Inventor/Transfer-custom-library-to-from-Inventor-2011-to-Inv...
If yes, does your library appear without any exclamation mark in the Configure Library dialog of the project?
If yes, if you browse to the Desktop Content location, select the idcl file corresponding to your library, right- click on it, Properties, is the Read-only box checked?
If yes, please, uncheck it and the problem should be solved.
If not, from the Configure Library dialog, create a new library.
Is the new library Read only as well?
Thanks and regards,
Alessandro
Alessandro Gasso
Product Support Technical Lead
MFG - Inventor
MariaManuela
Message 5 of 8 (1,340 Views)
09-06-2011 09:14 AM in reply to: jeanchile
Ok..
How you migrated your library?
Try to access to your libraries location and change the libraries properties (uncheck the Read-Only option)
see the image
Maria Manuela Pinho
Valued Mentor
jeanchile
Message 6 of 8 (1,325 Views)
09-06-2011 10:31 AM in reply to: alessandro.gasso
Yes
Yes
No, it is unchecked
No, any newly created library is labeled Read/Write.
Thank you for the help. Have you got anything else?
Valued Mentor
coreyparks
Message 7 of 8 (1,318 Views)
09-06-2011 11:45 AM in reply to: jeanchile
This happens here as well.  I have narrowed it down to our change from Windows xp to Windows 7 64 bit.  In this change we started using the UAC and we have now had local admin rights taken away from us.  In order for us to edit any content center libraries we need to have local admin rights and we need to turn the UAC off.  Our files are located on the server as well.  Do you have local admin and UAC turned off already?  If not can you turn them off?  Good luck.
Please mark this response "Accept as solution" if it answers your question.
Corey Parks
IV2014 Factory Design Suite Ultimate
Windows 7 64 bit
Synergis Adept document management software
16gb RAM --- Nvidia Quadro 4000 2gb
Valued Mentor
jeanchile
Message 8 of 8 (1,286 Views)
09-06-2011 08:35 PM in reply to: coreyparks
coreyparks wrote:
...I have narrowed it down to our change from Windows xp to Windows 7 64 bit. ....  Do you have local admin and UAC turned off already?
Thank you Corey! You are a champion and have won the grand prize. Go tell your boss I said to give you a raise! We too have upgraded our OS in the same fashion. Luckily, I have admin rights, but unfortunately, I have to change my UAC setting every time I need to edit our CC library which blows. :smileysad:
Now if I can just figure out how to get my CC files to not save with that stupid icon and use my last model view by default....
