Inventor Forum
Change Level of Detail on pipe Runs for Drawing
2 REPLIES 2
hirschaplin
282 Views, 2 Replies
So, I have built our pipes in different runs and routes under our main Tube and Pipe Assembly. On the main Pipe assembly I'm able to change to different LOD to remove Valves and Gaskets, but not on the lower level runs.
The purpose of doing this is to be able to create drawings on every run without gaskets and valves, but as of now the only option i have is to supress these items on every sheet and I'm guessing there is a better way.
So if anyone has som input i would be grateful.
2 REPLIES 2
mdavis22569
in reply to: hirschaplin
You could use View Representation. Go to the assemblies. and make a new one under views... Turning off and off what you need in each VR. Then you can adjust the 2 views to whichever VR you want to be showing. Mike
Mike Davis
hirschaplin
in reply to: mdavis22569
Mike,
Thanks i used supress in my Run assemblies and couldn't save the changes, but now when creating View instead of Detail, and visibility instead of supress it works thanks.
