I have a circular pattern. Is it possible to change the face color on the surface of the feature and have it reflected on all the other features? Thanks.
Solved by Millehuse. Go to Solution.
If I understand correctly...
1) Right click the "Circular pattern" in the browser
2) Select Properties
3) Feature Color Style - change this value
Best Regards
That's what I ended up using and it worked fine, but is there a way to change just one face on the feature that's being patterned and have it be changed on all the rest? Thanks.
No.
miss post.
@JimSteinmeyer wrote:miss post.
What does this mean?
The answer to Nate's question is simply - no.
It means that I wrote an answer and then after posting reread the origional post to be sure I had things right and found that I was wrong. I then went to edit my post and did not see a way to delete it so rather than leaving the post sounding like I am dumber than I am, I erased it. now I see that it could have been deleated.
