Inventor General Discussion
Distinguished Contributor
jbelle7435
Message 1 of 6 (518 Views)
Change Comma to a Period
518 Views, 5 Replies
11-19-2013 01:19 PM
Descriptions are the hardest part for me to change???
I looked through other threads. I see a hotfix but for 2011. I have 2012...
Inventor 2012
Valued Mentor
graemev
Message 2 of 6 (503 Views)
Re: Change Comma to a Period
11-19-2013 02:03 PM in reply to: jbelle7435
I would expect this is driven by the metric dimension style's decimal marker field:
Manage Styles - Dimensions - ( expand and pick the appropriate style) - Units (tab) - Units (zone) - Decimal Marker (dropdown list of two: decimal or comma.)
Maybe.
jbelle7435
Message 3 of 6 (486 Views)
11-19-2013 03:39 PM in reply to: graemev
tomorrow I will check this. Thanks
Inventor 2012
jbelle7435
Message 4 of 6 (450 Views)
11-20-2013 05:15 AM in reply to: graemev
"Manage Styles - Dimensions - ( expand and pick the appropriate style) - Units (tab) - Units (zone) - Decimal Marker (dropdown list of two: decimal or comma.)"
#1. I followed your idea and lets say one of ALL my Dimension styles had a comma. DEFUALT(ISO). I changed that from comma to a period and it worked. Then I wondered how am I using DEFAUT(ISO) as my dimension style..????
#2. If you go to your Object Defaults: There is this one object called Hole Tag (See all objects to find it)Once your change that to your Dimension style with the Period and whatever decimals palces* you want then it works and is set in stone for that description column. Updating the Hole note object  is not good enogh to fix this issue!
*Dimesion style-->"notes and leaders" tab-->"Precision and tolerance" button-->Use global(Units tab)or set your own with the drop down Primary
Inventor 2012
Valued Mentor
Mason-Paul
Message 5 of 6 (429 Views)
11-20-2013 06:14 AM in reply to: jbelle7435
"Then I wondered how am I using DEFAULT(ISO) as my dimension style..????"
IF you have several Dimension styles, as I do, from "ANNOTATE "select "DIMENSION", as normal, then from "FORMAT" in lower drop down saying "BY STANDARD" select dimension style you want to use from those displayed.
Selecting different saved dimension styles.
NOTE that in your menu may layout will be different from that shown as I moved the format box.
Bur before you can use a personal dimension style you'll need to BOTH create and save it
If your not to sure how to Crete and save customized Dimension styles I have several customized styles, most using the (.) as the decimal instead of (,), that I can let you have to get you going then all you have to do is import them.
Inventor 2014 Pro
HP xw8400 workstation
2 x Xeon duel-core 3Ghz CPU , 32 GB Ram
64bit Windows 7 Pro
AMD FirePro V3900 (ATI FireGL) (1GB RAM)
Ashington Northumberland (UK) ~ Home to the WORLD FAMOUS Pitman Painters Group
jbelle7435
Message 6 of 6 (420 Views)
11-20-2013 06:50 AM in reply to: Mason-Paul
I already created my own style and am happy with it. I fixed one bug but there will be more I run into. When you make your own style or how I did it, basically left stuff hanging out there to be fixed along the way. At least I know where to fix them and update my personel defaults....
Inventor 2012
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
