As I remember by picking different faces or even the opposite side of the part you can
minimize it. I think there is still cases that get through no matter what you do though.
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Craig Nunn" wrote in message
news:D2CA206CC0E3E5184FDC9AF4DB6E63A9@in.WebX.maYIadrTaRb...
> When I flatten a Sheet Metal part with a Chamfered/Countersunk hole in
> it the flattend part shows the through hole as the diameter of the
> Chamfer/CounterSink. This get tranfered to my tuuret. This is bad.
> Is there something I can do to prevent this?
> Craig Nunn
