Hey guys,
I have an assembly that i want to insert in another assembly. When i do insert it i try to make it "Adaptive" but the option is graded out/not available. How can i make it Adaptive?
Solved by blair. Go to Solution.
Adaptive requires geometry from other items to be projected and referenced by items within the sub assembly. Possibly you wish for a sub assembly such as a hinge to move/articulate within the main assembly, look at "Flexible".
RMB on the sub assembly within the main assembly and select "Flexible" from the drop-down menu.
BINGO! yup thats what i wanted.. I want a hinge and a Lift support (two different assemblies with their own constrains) to work together. thanks
