Inventor Forum
Cannot snap to sketch line midpoint (no green dot) 2013
6 REPLIES 6
ggoodey
3332 Views, 6 Replies
Hi All
Hopefully this is an easy one...
When I use a tool such as 'move'/'select base point' in the sketch environment, I used to be able to select line midpoints.
Is this no longer possible?
My constraint options seem to be fine...
Recently upgraded to 2013
Grant
6 REPLIES 6
Xun.Zhang
in reply to: ggoodey
Hello, ggoodey
Thanks for your question, unfortunately, the Mid Point not supported for base point selection so far, please create a contribution line which could snap to the Mid point first to help identify the real point for the base point when you try to move the sketch with Mid point.
I will submit a wish to out internal system for enhancement in the future, thanks a again.
Xun
Tags (1)
ggoodey
in reply to: Xun.Zhang
Thanks Xun
I was so sure I could do this pre-2013
Never mind...
Xun.Zhang
Hello, ggoodey
Checked in several release pre-2013, such as 2011 and 2012, your requirement not supported, a wish tracked in our system, we hope it will be fix in a short time, and I will let you know once it got fixed.
Xun
ggoodey
No worries!
Thanks again
yomogidami
Hello !
I tried to move a Sketch block ( Insert point selection)
but could not.
It will be usefull to select Midpoint  also Sketch block.
Sorry,Long line !
Inventor2012,2013
Windows7 64bit
Japan
YMO
Xun.Zhang
in reply to: yomogidami
Hello, yomogidami
Yes, we noticed that it will be better if mid point supported when sketch move, thanks for your follow up question, I'll reply you once it got fixed.
Many thanks for your questions again.
Xun
