I cannot select the sketch for slice, although it's a view attached sketch
Hi Karol,
You need to create a projected view and apply Slice operation to the projected view. Slice operation slices a view using sketch from a different view.
Ladislav
I want to slice the part along the sketch line marked with the red arrow.
No command lets me do a projected wiew along this line.
The Projected command only makes horizontal, vertical or isometric views.
The Auxiliary needs an edge or a line from the model, and i made an attached sketch.
The section command doesn't use sketch lines.
Hi Karol,
can you please try this:
1) RMB on Sketch2->Create Section View
- it's fine to do it in Browser
2) Check Include Slice in the Section view dialog
3) Place the view
Is this what you need?
Ladislav
