Dear all,
I am not able to move any of the views in my drawing (*.idw). As instructed by the help web page this should be as easy as "click and drag the red border", but this does not work. I cannot move the dimesion annotations either.
I am using Inventor 2014.
Any idea would be appreciated. Thank you very much in advance.
Kind regards,
Fabian
Solved by fabian.arellano. Go to Solution.
Do you see the Move mark in the right of mouse when you hover your mouse at the edge of views? If you see it, right-click and drag the view.
Try left click on mouse,hold down and drag,do this close to the corner, inside of the red border.
Hope this helps
Dear all,
Thank you very much for your replies.
I have no idea what was wrong, but after a couple of days after I came back to the document problem was solved. I assume I accidentally changed a configuration option in the document that was set to its default value when I restarted Inventor.
Kind regards,
Fabián
