When sketching on the face of a solid, using the projected geometry of the edge, I get the error message "cannot extend a curve that is reference geometry" when trying to extend the line.
Solved by WHolzwarth. Go to Solution.
@tmccar wrote:
.... using the projected geometry of the edge, ..."cannot extend a curve that is reference geometry" when trying to extend the line.
Projected geometry is what it is. You would need to Break Link the geometry if you want to edit it.
If it is just a line (and not a curve (understanding that in math a line is just a special curve)) I would simply turn it to construction and trace overtop of the projected geometry (I always do this in all cases). That way if I make a significant change earlier in the history my entire part doesn't "go sick", only minor bits of sick geometry to fix.
You are constrained to endpoints (and where did you intend to extend to).
IMO, you should use separate lines with colinear constraints.
Walter
Walter Holzwarth
Hi tmccar,
Generally speaking I think the wh's collinear constraint approach is the best approach, but attached is an alternate method.
I hope this helps.
Curtis
Curtis, I like your way. No sketching and constraining is needed with your solution for this special case.
Walter Holzwarth
