Inventor General Discussion
Distinguished Contributor
Karol-Or
Message 1 of 5 (406 Views)
Cannot exclude parts in a derived assembly
406 Views, 4 Replies
07-14-2013 12:34 PM
Look at the text in the picture, it's from a tutorial.
It says i can exclude parts from the assembly, when i insert it as a derived part, but the exclude button is greyed in the insert derived part dialog box
Valued Mentor
yannick3
Message 2 of 5 (392 Views)
Re : Cannot exclude parts in a derived assembly
07-14-2013 04:18 PM in reply to: Karol-Or
Hi
go to representation tab and uncheck associative
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
Karol-Or
Message 3 of 5 (352 Views)
07-15-2013 12:46 PM in reply to: yannick3
Where is the representations tab?
I can't find such a tab on the ribbon, at the top of the screen, and neither in the application and ducument settings commands
*Expert Elite*
JDMather
Message 4 of 5 (340 Views)
07-15-2013 02:00 PM in reply to: Karol-Or
It is in the Derive Component dialog box.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Employee
csaba.stupak
Message 5 of 5 (325 Views)
Re: Cannot exclude parts in a derived assembly
07-15-2013 11:51 PM in reply to: Karol-Or
The Derived Assembly dialog contains 4 tabs - Bodies, Other, Representation, Options. The Representation tab also affects how the objects are derived. The DesignView combobox - all visible objects are included by default and invisible are excluded (if the design view visibility can be applied to the object, note not all object can be controlled by design view visibility).
Moreover if the associative design view checkbox is checked we lock this behavior. It is not possible to include/derive hidden objects and/or exclude visible objects.
You can uncheck the associative design view checkbox - as it was suggested. You can also define a design view in the source assembly and adjust the visibility of the occurrences (parts). Based on the visiblity the derive will include/exclude the parts.
Csaba
You are not logged in.
Announcements
Need installation help?
Ask the Community
Inventor Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Autodesk Inventor helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
