Inventor Forum
Cannot exclude parts in a derived assembly
4 REPLIES 4
Karol-Or
2360 Views, 4 Replies
Look at the text in the picture, it's from a tutorial.
It says i can exclude parts from the assembly, when i insert it as a derived part, but the exclude button is greyed in the insert derived part dialog box
4 REPLIES 4
yannick3
in reply to: Karol-Or
Hi
go to representation tab and uncheck associative
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
Karol-Or
in reply to: yannick3
Where is the representations tab?
I can't find such a tab on the ribbon, at the top of the screen, and neither in the application and ducument settings commands
JDMather
It is in the Derive Component dialog box.
csaba.stupak
The Derived Assembly dialog contains 4 tabs - Bodies, Other, Representation, Options. The Representation tab also affects how the objects are derived. The DesignView combobox - all visible objects are included by default and invisible are excluded (if the design view visibility can be applied to the object, note not all object can be controlled by design view visibility).
Moreover if the associative design view checkbox is checked we lock this behavior. It is not possible to include/derive hidden objects and/or exclude visible objects.
You can uncheck the associative design view checkbox - as it was suggested. You can also define a design view in the source assembly and adjust the visibility of the occurrences (parts). Based on the visiblity the derive will include/exclude the parts.
Csaba
