Inventor Forum
Cannot change the Representation in 'Drawing View'
3 REPLIES 3
off2board
1786 Views, 3 Replies
I want to change my level of detail on one of my drawing views, but it locked out (or greyed out).  typically, all you have to do is uncheck the associative link from the master view, and that enables the ability to change 'position', or 'level of detail'...but in this case its locking me out completely.
3 REPLIES 3
jalger
in reply to: off2board
Hi Off2Board,
It looks like its a vaulted file.
Did you take ownership of the file before creating the Drawing?
Try Taking ownership of the file then see if the position reps are available. (could be it thinks its in use by someone else)
James
James Alger
(I'm on several hundred posts as "algerj")
Work:
Dell Precision 5530 (Xeon E 2176M)
1tb SSD, 64GB RAM
Nvidia Quadro P2000, Win10
off2board
in reply to: jalger
Doesnt appear to be a vault issue.  Closed everything related to vault and opened up an old assembly on my local drive, then put it into a drawing and Im having the same issues.  Even tried using Autocads standard template.  Tried it on a coworkers computer and same issue.
I am wondering if its related to SP2 because I've never seen this issue before.  Odd.
swalton
It looks like your view is a child of another view.  I did not think that it was possible to change the position rep or LOD of a child view to something different than a parent view.  However, you can do that with design views.
You might have to replace the child view with a new base view to get what you want.
Steve Walton
Inventor 2023
Vault Professional 2023
