When i trying revolved is not working. I have learning version Inventor Proffesional 2012 . It is wokked before andnow when i finish skech and and press revolved even with one only profile in not showing revoleve previous or not allw me to chose profile. Any help plesae>
Hi 900-********,
The details you've provided are a bit spare. Can you provide a screen shot or attach the model file?
Also it looks like your user name is your product serial number? If so you might want to change it to something else, so someone doesn't try to use it to register their free download.
I hope this helps.
Curtis
Welcome to the forum.
Like Curtis mentioned more detail and even some images would help us to resolve your issue.
My first thought based on what you described is that you do not have an enclosed sketch on one side of a center line.
Check to see if this is indeed the case.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
Click here (see image). Does it work now?
The CADWhisperer YouTube Channel
