Inventor General Discussion
Distinguished Contributor
Zoltan78
Message 1 of 4 (194 Views)
Can't split solid
194 Views, 3 Replies
03-13-2014 02:56 AM
I'd like to split the last remaining solid (Solid22) in two with Workplane3 but I can't (see attachment). It says: could not build this split. What am I overlooking?
Zoltan
Software: Inventor Series 2011 SP1 x64
OS: Windows 7 Professional x64
CPU: Core i7-4770K
RAM: 2*4Gb Corsair
VGA: GTX 560 Ti
Valued Mentor
Valued Mentor
wh
Message 2 of 4 (179 Views)
Betreff: Can't split solid
03-13-2014 03:35 AM in reply to: Zoltan78
If a solid has two ore more separate lumps, Split feature can't do it.
Use Copy object and Face delete with lump option, instead, Zoltan.
Walter
Zoltan78
Message 3 of 4 (168 Views)
03-13-2014 03:51 AM in reply to: wh
Based on your text that the problem is they aren't connected, I simply connected the two parts with an extrusion. I could split then, followed by a trim removing the unnecessary part. Thanks!
Zoltan
CPU: Core i7-4770K
RAM: 2*4Gb Corsair
VGA: GTX 560 Ti
Valued Mentor
Valued Mentor
wh
Message 4 of 4 (160 Views)
03-13-2014 04:06 AM in reply to: Zoltan78
:smileywink: That's another way to Rome ..
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
