Inventor Forum
Can't split solid
3 REPLIES 3
Zoltan78
1307 Views, 3 Replies
Can't split solid
I'd like to split the last remaining solid (Solid22) in two with Workplane3 but I can't (see attachment). It says: could not build this split. What am I overlooking?
Zoltan
Software: Product Design & Manufacturing Collection
OS: Windows 10 Professional x64
CPU: Core i5-8600K
RAM: 2*8Gb
VGA: GTX 3070
3 REPLIES 3
WHolzwarth
in reply to: Zoltan78
If a solid has two ore more separate lumps, Split feature can't do it.
Use Copy object and Face delete with lump option, instead, Zoltan.
Walter
Walter Holzwarth
Zoltan78
in reply to: WHolzwarth
Based on your text that the problem is they aren't connected, I simply connected the two parts with an extrusion. I could split then, followed by a trim removing the unnecessary part. Thanks!
Zoltan
CPU: Core i5-8600K
RAM: 2*8Gb
VGA: GTX 3070
WHolzwarth
😉 That's another way to Rome ..
Walter Holzwarth
