Inventor Forum
Can't remove feature adaptivity in a part.
11 REPLIES 11
Message 1 of 12
awatt
8511 Views, 11 Replies
Inventor Pro 2013:
Checking the 'adaptive' checkmark on the feature doesn't make the checkmark go away.  The sketch doesn't give me a link to break.  The 'adaptively used in assembly' option is greyed out.  The feature properties doesn't give me any useful options.  I've looked through my assemblies, and I don't see any that are actually using it.
What am I missing?
11 REPLIES 11
Message 2 of 12
awatt
in reply to: awatt
After Redefining the sketches, I was able to delete the work planes left over from the original assembly part.  Then I was able to unshare the sketch, and finally remove the adaptivity.
Message 3 of 12
pdessai
in reply to: awatt
I deleted the sketch having the adaptivity but how to remove the adaptivity from part?
The part is in framework.
Kindly suggest to resolve.
Message 4 of 12
Gabriel_Watson
in reply to: awatt
If this issue happens with a hole feature, for example, there is an alternative way to fix it...
(cannot find "Adaptive" checkmark/option here? don't panic...)
First, switch the hole feature to "Linear" Placement:
Then pick any spots, just temporarily. Repeat this for all the features using the same shared Sketch.
Now right-click the Sketch (which is not being used by any features anymore), and you will see the option to remove its adaptivity:
Finally, you can restore your hole feature(s) back to using the points from your sketch:
Message 5 of 12
kelly.young
in reply to: pdessai
@pdessai if you have another issue at the part or assembly level you should post a new topic since this one has a solution.
For the part if there is any Project Geometry from another part it will remain adaptive. You would have to go into the part sketch, delete/break the reference, then you can RMB on the sketch and/or feature to turn off the adaptability.
Message 6 of 12
Kelly,
Even if you delete EVERYTHING within a sketch, it will be stuck as adaptive in the case I pointed above, until you uncheckmark Adaptivity after making the shared sketch independent of any features.
Message 7 of 12
gregC9RQG
in reply to: Gabriel_Watson
WHY ?????? omg not good enough.
Message 8 of 12
This looks to have worked in older versions, but I have the same situation in a newer version and this workaround no longer works.
Message 9 of 12
Have you replicated the same issue using different PCs? Are you able to share a sample here and tell us which version to try with?
Message 10 of 12
This was in 2019.6.  We are going to roll out 2023.2.  I just checked 3 files.  One worked in 23, two still have the same issue.  With assembly adaptivity off, the one file worked even without editing the sketch, but it is an extrusion not a hole.  The other two are referencing hole centers and they both still don't work with this method.   Yes, this is on a different machine as well.
Message 11 of 12
I would love to have a sample to tinker with. If you can attach here an almost empty assembly with just a single part and feature that alone can replicate the issue.
Oh, and you should also try a "Rebuild All".
Message 12 of 12
Hi John,
On possibility is that the adaptive part has a non-Primary Model State, right? If yes, the adaptive flag will not be available. In general, Adaptivity and non-Primary Model State are like mutually exclusive. Model State table cannot manage cross-part relationship at the moment.
Please share the failed example here. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
