Inventor Forum
Can't move a flexible assembly
4 REPLIES 4
Myles1
1922 Views, 4 Replies
I have a sub-assembly that is flexible, (constrained properly, not grounded) and when I try to move it in the main assembly, I get the "universal NO" symbol attached to my cursor.  There are no constraints preventing the movement in the sub, since I can move it however I want when the sub is opened.  Any reason why this would happen?  And how can I fix it.
Inv 2011
4 REPLIES 4
Curtis_Waguespack
in reply to: Myles1
Hi Myles1,
Are there any Positional representations at play here, in the subassembly and/or top level assembly? That's the first thing that came to mind.
The second suggestion would be to go to the Manage tab > Rebuild All button and see what happens when you click it.
Additionaly, you might provide a screen capture of the browser at the subassembly and top level assembly, so others can see what you're seeing, hopefully something will stand out.
I hope this helps.
Curtis
blair
in reply to: Curtis_Waguespack
Any bad/sick constraints will stop the item from moving as well.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
mcgyvr
in reply to: blair
by "flexible" did you mean you right clicked on that subassembly in the top level sub-assembly and checked "flexible" or just the fact that it "should" be flexible..
Just checking...
Myles1
in reply to: mcgyvr
I right clicked on the sub in the main assy, and selected "flexible".
