Good morning,
i want to make an extrusion with this reptangule but i can't understand why the software can't make this because , when i click the confirm botton for the extrusion, it appears an error window.
There somen who can help me?
Thank you in advance
Best regards
Solved by PACDrafting. Go to Solution.
Works fine here.. Whats the error?
Good morning,
when i click on the rectangle to make the extrusion, it appears an error message that says that processing did not change the specified number of faces (and could not have affected part). I can accept, but working is not well done.
And i don't undestand evene the recrangle is green and not blue.
Best regards
You need to select the join button. Not the cut button as you have shown on the bottom window box.
