Inventor Forum
Can't extrude or cut on model
5 REPLIES 5
1102 Views, 5 Replies
So I started on this project recently and was not the original modeler.  This section of pipe has some problems where I'm guessing a sweep went wrong.  I've tried everything I know to do to try to fix this section but haven't had any luck.
- This model has no tree and is shown as one soild "base"
- I tried to extrude cut the bad section
- I tried spliting the bad section
- I exported the file as an IGES and then tried to remove bad section
I'm sure there are some other round about ways I tried that I can't think of but in the end nothing has worked.
Can some one give me some ideas of how to fix this section of pipe?
Mike
5 REPLIES 5
JDMather
Do you still have the original file (before any attempts to "fix")?
CCarreiras
Hi!
You can delete some faces and reconstruct the system with some loft, sweep, patch surfaces. In the end, stitch all surfaces to have a solid.
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
in reply to: JDMather
Yes I do.  I didn't want to post it since it has information that I would rather not share.
in reply to: CCarreiras
Can you go into more detail about how to delete faces.  I have little experience with surfaces.
Ok I figured it out and yes that worked. Thanks
