I can not create a silhouette curve, the body button is turned off and displays the following message:
""string resource not could be loaded (and is missing?) for id 36f8 (error 0).
someone else had this??
how I can fix this?""
Tnx
Tnx
Attach the file here that exhibits this behavior.
What plane are you trying to project the curves onto?
I was not able to reproduce the error - can you describe exact steps?
I follow this steps:
open the file
create 3d sketch
silhouette
supposedly the tool should allow me to select the solid body, but the button body is with the error shown in the picture
tnx
I attach another file
regards
@Anonymous wrote:supposedly the tool should allow me to select the solid body
You only have one solid body - so it is selected automatically?
I still don't understand how you are getting the error - it works fine for me on your files.
I repaired the installation of the inventor, and the malfunction was corrected, my son installed without my knowing a game that corrupted the system, thanks for the help, and sorry for waste your time
many thanks for your patience
regards
I have exactly the same problem. I also reinstalled Inventor 2013 completeley but still have this problem.
String resource could not be loaded (and is missing?) for id 36f8 (error 605136f8)
appears if I hover the mouse over the body button.
I use your file as well and get same error. I tried also on different machines (using Inventor 2013 trial) but the problem is still there. So it could not be solved by re-installation.
I use Windows 7 professional SP1, Inventor 2013 (trial), SP1.1 Update 2
Any further ideas?
Thanks!
