Trying to get my Quick Access tool bar set back up after an upgrade to IV 2014 since it didn't carry over from 2013. For some reason, the option to add the Measure command is greyed out. The option is available on every other command except the ones that are already there.
First instinct is that it must already be there but it is not. I checked all modes, Sketch, Part, Assembly and it does not show up under any condition.
How can I fix this?
thanks.....
Solved by EScales. Go to Solution.
The measure tool is already in the Quick Access Toolbar, by default. You just have to check it, to make it visible.
