Inventor General Discussion
Active Contributor
conbuc
Message 1 of 3 (185 Views)
Can I place an empty .ipt file into an assembly then start working on it?
185 Views, 2 Replies
10-19-2012 11:09 AM
Or do I have to create the new part, save it, then go into my assembly and place it?
Thanks.
Curtis_Waguespack
Message 2 of 3 (178 Views)
Re: Can I place an empty .ipt file into an assembly then start working on it?
10-19-2012 11:29 AM in reply to: conbuc
Hi conbuc,
If you go to the Assemble tab and use the Create button, you can choose a template to create an empty *.ipt from and place it into the assembly.
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
Active Contributor
conbuc
Message 3 of 3 (118 Views)
10-22-2012 07:16 AM in reply to: Curtis_Waguespack
That button was staring right at me...thanks!
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
