Inventor Forum
Can I calculate the total surface area in inventor?
8 REPLIES 8
Message 1 of 9
Infallable
10249 Views, 8 Replies
I want to calculate the total external surface area of the attached manifold.  When I use the iProperties tool,  it give me the surface area including internal surfaces of tubulars etc.
Please help!!
Thanks in advance.
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: Infallable
Perhaps you can create a ShrinkWrap derived part patching the holes and flood filling the interior.
Message 3 of 9
RossSapienza
in reply to: JDMather
How do you "FLOOD FILL THE INTERIOR" ???
Inventor 2017, AutoCAD LT 2017
Windows 10 Pro
Intel Core i7 @ 3.6 GHz
16 GB RAM
AMD Radeon RX 560
Message 4 of 9
JDMather
in reply to: RossSapienza
Attach your file here.
Message 5 of 9
RossSapienza
Okay, but wasn't sure if I needed to unkink the shrinkwrap or not. Here is my part.
Windows 10 Pro
16 GB RAM
AMD Radeon RX 560
Message 6 of 9
JDMather
Isn't this really the same thing 4 times?
One "row" would have been enough.
Don't do anything with it.
Message 7 of 9
johnsonshiue
In Shrinkwrap dialog or Derive dialog, there are settings: one is called "Remove internal void" and the other one is called "Hole patching." Try turning them on. The resultant part should be shell-free. Or, you can try to do it manually. Simply use Boundary Patch command to cover all the openings. Then use Sculpt command to turn it to shell-free solids.
Thanks!
Software Test Engineer
Message 8 of 9
RossSapienza
in reply to: johnsonshiue
this doesnt seem to work for me ... I get the same surface area for the shrinkwrap as I do for the original assembly.
Windows 10 Pro
16 GB RAM
AMD Radeon RX 560
Message 9 of 9
adam
Hi Ross.
As per this thread;
https://forums.autodesk.com/t5/inventor-forum/inventor-2020-shrinkwrap-surface-area-not-recalculatin...
Shrinkwrap does not calculate outside surface area.
You will need to create a derived part, under the Options tab, there is a check box to fill internal voids.
The surface area in the iProperties of the derived part should be what you are after.
Adam Johnston
Design Draftsman. Whitty Engineering.
DELL Precision 7530, Windows 10.
