Dave,
I just noticed the log file name would depend on your installation flavor,
but the size is about tens of MB.
The name could be AIP11Install.log for AIP Full flavor, AIPRS11Install.log
for Routed System, AIPSIM11Install.log for Simulation System.
Sorry for any confusion caused.
Thanks.
-Oboe Wu
AIP QA
"Oboe Wu (Autodesk)" wrote in message
news:5235542@discussion.autodesk.com...
Dave,
Thank you for your following up, but the log file is not for Inventor setup.
Could you attach this one at:
%temp%\Autodesk Inventor 11 Setup.log which is about 30M bites?
One guess is that some operating system components are not correctly
installed or registered.
Are your two machines using the same operating system? What is it? How's its
configuration?
If it's windows, could you browse to OS Root drive:\WINDOWS\system32 and get
msxml4.dll registered?
The steps are:
1. Type in "cmd" in Run dialog from windows start menu;
2. Browse to OS Root drive:\WINDOWS\system32;
3. Type in "regsvr32 msxml4.dll"
Let me know if there are still problems.
Thanks.
-Oboe Wu
AIP QA
wrote in message news:5235191@discussion.autodesk.com...
1. I installed everything except Vault. We'll get back to that later.
2. How would I know? I ran the bat file and it still doesn't work. Should
I reboot?
3. Nope. Relatively clean install.
Mahesh (below) asked for the mdsetup and setup logs. This is what I can
find:
As far as the laptop goes, I did nothing more than started a command,
cancelled, closed AIP, and turned the computer off.
Nice to see you are interested, though.
Dave
