Im trying to animate the Cable Pulley System of a Home Gym Machine. I have already put up the assembly but I cant figure out how to do this. For instance, on the first attachment you can see the the cable is supposed to be pulled by a force from the far right corner where the last pulley is displayed (where it says 47). The cable then has to go through the entire sequence of pulleys (attachment #2 illustrates this better), rotate them while it's being pulled and finally lift the Selector Rod (#28) which is where the Weight Plates are ment to be attached (attachment #3 shows a diagram of the entire machine). Does anyone know how to do this?
