Inventor General Discussion
Active Member
SERGE
Message 1 of 9 (765 Views)
CONTENT CENTER / DESIGN ACCELERATOR DOCTOR, ERROR
765 Views, 8 Replies
09-28-2006 06:01 AM
Everytime I try to place a #8 machine screw type II screw from the content center I get a Design Accelerator Doctor error saying: "Modeling: Failed to insert a part into assembly!".
But if I place a Type I machine screw it works fine. Also if I replace the Type I screw with the Type II (the one I have a problem with) it replaces it no problem. So basically if I want to place a #8 Type II screw I have to place a Type I and then replace it with the Type II.. Anyone else have this problem?
*Lukas Polansky \(Autodesk\)
Message 2 of 9 (764 Views)
Re: CONTENT CENTER / DESIGN ACCELERATOR DOCTOR, ERROR
09-29-2006 04:36 AM in reply to: SERGE
Hello Serge,
can you please post:
- exact standard of the bolt - I tried all Countersunk bolts Type II, Thread
Description #8 and couldn't reproduce your problem
- What is the Nominal Length, Thread Type and if applicable Head Diameter of
the bolt?
I will look at it and let you know.
Thanks and regards,
- Lukas
Lukas Polansky
DAcc QA Engineer
wrote in message news:5343752@discussion.autodesk.com...
problem?
Active Member
SERGE
Message 3 of 9 (764 Views)
10-02-2006 11:33 AM in reply to: SERGE
It's the Cross Recessed Pan Head Machine Screw - Type II - Inch. Everytime I go to edit the screw before placing it I get the error.
Message 4 of 9 (764 Views)
10-11-2006 03:09 AM in reply to: SERGE
Hello Serge,
I am sorry for the delay. I am still not able reproduce it. Please try to
clear the CC cahce - browse to "c:\My Documents\Inventor\Content Center
Files\R11\en-US\Cross Recessed Pan Head Machine Screw - Type II - Inch"and
delete the Corss Recessed Pan Head Machine Screw.... folder. If it won't
help would you please let me know which sizes exactly have the problem or is
it all sizes? I know it's #8 but I am not sure which Nominal Length and
Thread Type is it.
Thanks and regards,
- Lukas
Lukas Polansky
DAcc QA Engineer
wrote in message news:5347730@discussion.autodesk.com...
Active Contributor
kevinbosch
Message 5 of 9 (764 Views)
12-19-2006 08:43 AM in reply to: SERGE
I REALIZE THIS THREAD IS A LITTLE OLD BUT I AM HAVING THE SAME TYPE ISSUE USING HEX BOLT OR HEX HEAD CAP SCREW. ARE THERE ANY SOLUTIONS OUT THERE
Active Contributor
mbaker
Message 6 of 9 (710 Views)
11-17-2010 07:58 PM in reply to: SERGE
Serge, yes I am having the same issue but with additional problems  - none of the Design Accel items will allow any creation. Just started today in a presentation, had never seen the errors or had any indication that a simple bolted connection would start this problem.
I've tested several other DA tool including the Shaft Gen and the roller chain and I always received the following..Design Accelerator Doctor, BTW have never seen this on a simple bolted connection..Or anything else...
Modeling: Failed to Create New Document?
What I have tried was unloading and reloading my Design Accelerator add-in's that did not work/help. I'm going to try a re-register  by running the RegisterDesignAccelerator.exe /uninstall  followed by the /install switch. I'm totally out of ideas, and cannot find any reason how or why this started...
Mike ????
Member
abhinavmasters
Message 7 of 9 (512 Views)
05-10-2012 10:14 AM in reply to: *Lukas Polansky \(Autodesk\)
Sir I am not able to design the shaft. I have opened the assembly and I wanted to deign shaft by using the design accelerator. Erros is :
Modelling: Failed to update the component "with some address of my working directory"
Attached is the error
RobJV
Message 8 of 9 (503 Views)
05-10-2012 05:12 PM in reply to: SERGE
Try finding that part in your CC folder, using Windows explorer, then delete it if it is there.
Member
abhinavmasters
Message 9 of 9 (492 Views)
05-11-2012 10:52 AM in reply to: RobJV
Thanks a lot sir. It is really helpful.
I wanted to add motor and encoder in my shaft design.
I don't know where I can add some standard motors and encoders in my design.
I tried seraching in internet, but couldn't found out.
Announcements
Need installation help?
