Serge, yes I am having the same issue but with additional problems - none of the Design Accel items will allow any creation. Just started today in a presentation, had never seen the errors or had any indication that a simple bolted connection would start this problem.
I've tested several other DA tool including the Shaft Gen and the roller chain and I always received the following..Design Accelerator Doctor, BTW have never seen this on a simple bolted connection..Or anything else...
Modeling: Failed to Create New Document?
What I have tried was unloading and reloading my Design Accelerator add-in's that did not work/help. I'm going to try a re-register by running the RegisterDesignAccelerator.exe /uninstall followed by the /install switch. I'm totally out of ideas, and cannot find any reason how or why this started...
Mike ????
Sir I am not able to design the shaft. I have opened the assembly and I wanted to deign shaft by using the design accelerator. Erros is :
Modelling: Failed to update the component "with some address of my working directory"
Attached is the error
Thanks a lot sir. It is really helpful.
I wanted to add motor and encoder in my shaft design.
I don't know where I can add some standard motors and encoders in my design.
I tried seraching in internet, but couldn't found out.
