On the module generating inventor springs 2012 can generate aconical spring? Someone could tell me how. Thanks
Solved by camilorivera8311. Go to Solution.
Are you referring to the Design Acclerator in the assembly environment or simply adding a taper angle in the part environment with the Coil feature?
I'm referring to the Design Acclerator in the assembly environment. Thanks
I don't think there is a way to do it with the DA.
Try the Content Center > Fasteners > Washers > Spring
Mike
Something like this?
More informatioin is needed.
Yes, just like that is what I need, but enabled to perform calculations on it.
Thanks.
Good Afternoon. This is the answer that give me the Autodesk specialist. Thanks for your colaborations.
"Dear Camilo Rivera
Thank you for contacting Autodesk Support.Your observation is correct, the module Inventor Design Accelerator does not support the creation of conical springs, springs can only be created straight through the tool."
"Accept as Solution" i'm using inventor. wire dia .055", oal= 1.705", od @ top = .630", od @ bottom = .725".
can you help?
Use the Coil feature.
Attach here what you have attempted so far.
