Inventor Forum
CHANGE COMMAS TO FULL STOPS IN HOLE TABEL
7 REPLIES 7
Message 1 of 8
2507 Views, 7 Replies
Why the hole chart has commas instead of decimal points I don't know but does anyone know how to change them? Even my VAR can't figure this out.
7 REPLIES 7
Message 2 of 8
blair
This might be related to number formating within the Windows O/S for country. Check: Start>Control Panel>Region and Language>Formats>Additional settings>Numbers>Decimal Symbol:
This also where IV picks its date format.
If it works, through a shrimp on the barbi for me
Delta Tau Chi ΔΤΧ
Message 3 of 8
in reply to: blair
Thanks Blair. Have checked that but no go. Regular and ordinate dims are fine, as are hoe notes. It's just the bloody hoe table decimal points. As a matter of interest how is your hole table formatted, commas or decimal point? Regards, Brendan Henderson BLH Drafting Services
Message 4 of 8
rdyson
How about here?
PDSU 2016
Message 5 of 8
blair
in reply to: rdyson
RBM on the Hole Table, to bring up the Edit Hole Table, at the bottom in the Column Settings, RMB on the XDIM and select Format Column. Over on the Units, in the Decimal Marker dialogue box, select .Period from the pull down menu. I suspect that yours is set to ,Comma.
Delta Tau Chi ΔΤΧ
Message 6 of 8
in reply to: blair
That's the trick blair. Thanks too you and to all who assisted. That's been bugging me for 2 years! Thought I better get it sorted once and for all before we upgrade to 2013 next week!
Message 7 of 8
in reply to: blair
Thanks blair. Your solution from 2013 still helping me on 2020. I just come across your prudent comment while seeking to eliminate the comma in Hole Table.
Message 8 of 8
Lancaster.B
Still Helping in 2024 😀
