One of the problems with the + recover is it shows you what is wrong but
it can be very difficult to get to. Try working in a 1,000 plus part
assembly and actually find the part that is having the problem. It sure
would be nice if Autodesk could add another option for "Open" or
"Isolate". More often than not, in a large assembly, the parts with
issues are buried or occluded by all the shadowed stuff in front of it.
In the case of constraints, the Doctor UI should provide a method for
isolating the "constrained to" parts like the constrained to filter. To
be done right, this would include a restore previous representation
(design view)
For parts with issues, a option to simply open the part would help a
lot. What I do today is have the Doctor take me into the part, then I
switch to "Feature" selection mode, highlight a feature on the part
(once I find it in the graphic window) then pick "Find In Browser" and
then RMB and pick Open Part.
Gary R. Smith (Autodesk) wrote:
>In the assembly, is the "Recover" (red cross) displayed as having found
>problems? Will that help you located the parts?
>Are there constraints placed to the bad parts? If so, perhaps flipping your
>browser into MODELING VIEW and then opening the Constraints folder will help
>you find the parts?
>The browser itself does not support a search function however, there is a
>FIND COMPONENTS IN ASSEMBLY function under the Edit dropdown menu which
>might also help you to isolate the suspect files.
