After changing part and file names in DA (in this case they are the same), The browser in the assemblies still list the old name. When you chk the properties in the browser name the part number did chg , but the old file name is still under the occurrance Tab and in the Panel bar tree????
A search shows this can happen to others, even in newer releases. MYCAD may have some program to fix this?
Manually changing the name again in the properties RMB does solve it, but is enefficient.
When changing the name in DA with edit it brings up a pop up window where you change the name, but the Part Number you chg within the DA manager blocks. Is the pop up window for the name standard, I thought i used to chg the name within the DA name block.
