ozstang65,
Often, as a first pass for help related scripting we will suggest the
following:
- Delete all Temporary Internet Files in IE (Tools>Internet Options>General
Tab)
- Check your IE security settings. The "Scripting" settings for Internet,
Local Intranet, and Trusted Sites should be set to enabled or prompt.
- Make sure that you have the latest Microsoft Updates installed.
- Re-register html help control:
1) Go to Start > Run
2) At the Run dialog, type the following:
regsvr32 C:\Windows\system32\hhctrl.ocx
If your system does not find the ocx control at this location, try doing a
search for it on your C drive.
There are certainly registry entries that could come into play but we try
not to resort to suggesting that you edit the registry as your first course
of action.
Gary R. Smith
Autodesk Manufacturing Solutions Division
Technical Publications - Subject Matter Expert
Portland, OR
2.33GHz 2GB IBM ThinkPad T60p; XP pro SP2
ATI Mobility FireGL V5250 driver: 8.293.1.0
