Inventor Forum
Bracket Flanges
14 REPLIES 14
Message 1 of 15
751 Views, 14 Replies
Bracket Flanges
I have posted files in CF. I have two almost identical Sheetmetal brackets
that have flanges that should be identical, i.e. the height. As far as I
can tell I have selected identical edges, sheetmetal styles etc... but one
is slightly taller than the other. I can not see what is "wrong" with them.
Do you see anything?
TIA,
Keith Bradford
CAD Director
SCS/Frigette
817.293.5313
www.scsfrigette.com
(Remove All Numbers From E-mail)
14 REPLIES 14
Message 2 of 15
Where are the files Keith?? Can't see them in CF.
--Rob Singlehurst
"Keith_Bradford" <7kbradford7@7scsfrigette7.com> wrote in message
news:10325ABADDD5497ED58F5F0B20BD5F53@in.WebX.maYIadrTaRb...
brackets
them.
> TIA,
> Keith Bradford
> CAD Director
> SCS/Frigette
> 817.293.5313
> www.scsfrigette.com
Message 3 of 15
For some reason it posted as RE: Bracket
Keith Bradford
CAD Director
SCS/Frigette
817.293.5313
www.scsfrigette.com
"Rob Singlehurst" wrote in message
news:044A1AA115519DF9403388921D0393B5@in.WebX.maYIadrTaRb...
> --Rob Singlehurst
> brackets
I
one
> them.
> > TIA,
> > Keith Bradford
> > CAD Director
> > SCS/Frigette
> > 817.293.5313
> > www.scsfrigette.com
Message 4 of 15
Keith
I don't see the post in Customer files either. Sometimes OE misses posts for some reason.
I tried looking for it on the Web side, but all the search turned up was this thread,
nothing in customer files
Kent
Member of the Autodesk Discussion Forum Moderator Program
Message 5 of 15
Nope still can's see it!!
--Rob Singlehurst
news:2DF69F955D08C426594AE29D5EDE3B68@in.WebX.maYIadrTaRb...
> Keith Bradford
> CAD Director
> SCS/Frigette
> 817.293.5313
> www.scsfrigette.com
> > --Rob Singlehurst
> > brackets
as
> I
> one
> > them.
> > > TIA,
> > > Keith Bradford
> > > CAD Director
> > > SCS/Frigette
> > > 817.293.5313
> > > www.scsfrigette.com
Message 6 of 15
I see it.
Search for "Bracket"
It was appended to a post with the same subject, by Russ Walker on 12/10/01
Mike
"Kent Keller" wrote in message
news:C6BB200C0BD7DD4F6EA89B039C1B4C3E@in.WebX.maYIadrTaRb...
> Keith
for some reason.
this thread,
> Kent
Message 7 of 15
Thanks Mike...I will repost it under Keith Bracket.
Keith Bradford
CAD Director
SCS/Frigette
817.293.5313
www.scsfrigette.com
"Mike Maenpaa" wrote in message
news:A40832703DD55AF24A85E4E31CF10FCD@in.WebX.maYIadrTaRb...
> I see it.
12/10/01
> Mike
> > Keith
posts
> for some reason.
> this thread,
> > Kent
Message 8 of 15
Keith
Are you talking about Flange 1 in each file? One is adaptive and has a different dim than
the other?? The face sketches don't have dims and the other flange appears to be the same
lengths
Kent
Message 9 of 15
I noticed that too. On one part, the edge selected for the flange is the
inside edge. On the other part, the outside edge is selected.
Keith, are you wondering why it's off by .001?
Mike
news:AF260166F91B6BE666734D85BF88B105@in.WebX.maYIadrTaRb...
> Keith
different dim than
> lengths
> Kent
brackets
Message 10 of 15
Ok, sorry about the ambiguity of the information provided. I will try to
get us looking and thinking the same. I think that I inadvertantly posted
the wrong brackets. I have reposted REVa.zip in Keith Bracket. This
assembly should have all neccessary constraints placed so that you may see
the problem. Yes I did make one of the flanges Adaptive but only to try and
solve this issue. I thought that if I made Flange 1 of one of the
componets, adaptive that I could constrain it to equal the height of the
other flange. I removed the Adaptivity of the flanges in this latest post.
I have ensured that the lasted posted files have flange 1 height set at
.405.
Thank you for your patience.
Keith Bradford
CAD Director
SCS/Frigette
817.293.5313
www.scsfrigette.com
> Keith
different dim than
> lengths
> Kent
brackets
Message 11 of 15
Yes I am wondering why it is off by .001.
Keith Bradford
CAD Director
SCS/Frigette
817.293.5313
www.scsfrigette.com
news:B86B14AA821E31C9BE4D0E6B57FB30A1@in.WebX.maYIadrTaRb...
> Mike
> > Keith
Message 12 of 15
Look at Part3 new_reva.ipt, open up the Parameters dialog. The dimension has
.405, but also has a tolerance dim of .4045 for Nominal & Model. I haven't
tried tolerance modeling yet, so I'm not sure how to change that. I think
that's where the .001 is coming from.
Mike
news:C82E21031B85769DE62CC4CBD796804E@in.WebX.maYIadrTaRb...
> Keith Bradford
> CAD Director
> SCS/Frigette
> 817.293.5313
> www.scsfrigette.com
> > Mike
> > > Keith
Message 13 of 15
Flange1 on Part3 new_revA has some problems. On one end of the part, there
is a wire showing where the bend starts. On the other end, the flange is
short. I logged a defect against it.
Loren Jahraus
Autodesk Inventor Workflow Team
> Keith Bradford
> CAD Director
> SCS/Frigette
> 817.293.5313
> www.scsfrigette.com
> > Mike
> > > Keith
Message 14 of 15
Thanks Mike. I repaired it though I am not sure exactly what I did that
solved the problem. In Part 3 per your keen eye, I opened the Parameter and
clicked in the Quation edit box of d2 (0.405) an arrow pops up and I clecked
it and went to Tolerence. Once there I changed the precision to 0. and the
Evaluate Size to Nominal. I saved and updated everything with NO change. I
then opened Part 3 again and Edited Feature on Flange 1 and typed in AGAIN
.405. Updated/Saved again returned to the Assembly and IT WAS CORRECTED.
Thank you for spotting this. I do not think that I would have ever seen it
and I am not sure how I fixed it but it is fixed now.
Is this TRULY OPERATOR error or Software? I can handle either answer being
correct. If it's me....I'll learn. If it's IV it'll be fixed. I would
just like to know which.
Keith Bradford
CAD Director
SCS/Frigette
817.293.5313
www.scsfrigette.com
news:FCADD852793B78182CB63A885601F672@in.WebX.maYIadrTaRb...
has
> Mike
> > Keith Bradford
> > CAD Director
> > SCS/Frigette
> > 817.293.5313
> > www.scsfrigette.com
the
> > > Mike
> > > > Keith
Message 15 of 15
LOL. THANK YOU!
Keith Bradford
CAD Director
SCS/Frigette
817.293.5313
www.scsfrigette.com
"Loren Jahraus (Autodesk)" wrote in message
news:4AB294918F2033FE1410CC443132B6F3@in.WebX.maYIadrTaRb...
> Loren Jahraus
> > Keith Bradford
> > CAD Director
> > SCS/Frigette
> > 817.293.5313
> > www.scsfrigette.com
the
> > > Mike
> > > > Keith
