Bolted connection follow pattern not work. When i use follow pattern in Bolted connection component not pattern
In your picture, I see all of the holes highlighted... looks like it's following the pattern. That screen shot doesn't show the completed process, does it not insert fasteners in all of the highlighted holes?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Feature pattern or Component pattern?
Attach your assembly here.
Your holes are placed at the assembly level, not at the part level. (open part and there are no holes)
Is this what you intended?
Im having a similar problem... its shows the wireframe view as though its going to place multiple screws in the assembly, but when i click apply, It places all the multiple holes but only shows 1 bolt on the first refernce that i choose. why does it not place all the bolts when placing the holes.
Thanks, Craig
