Inventor Forum
Bolted connection dialog Box will not show up
4 REPLIES 4
621 Views, 4 Replies
All of the sudden I cant get to my bolted connection dialog box.
1. The command runs and the prompts at the lower part of the screen show.
2. Have loaded and unloaded / restarted via add ins.
3. Have looked behind all windows ect on both of my 2 screens
Anything else to try?
Thanks!
Tags (1)
4 REPLIES 4
cbenner
What version of Inventor?  Do all your other dialogs work fine?  Has anything changes since it last worked?  Is the COntent Center loaded and working?  (just reaching now....)
Cadmanto
Have you tried this with Inventor being the only program running?
Have you tried the Alt-Tab key stroke that toggles through the programs to see if that triggers it?
See if this thread helps you.
http://forums.autodesk.com/t5/Inventor-General/Frame-member-insert-dialog-disappeared-out-of-visible...
Are you using dual monitors?
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
bob_holland
Ian,
Can you tell is if it works if a different person logs in?
Please post an update.
Thank you.
Bob Holland
Autodesk Product Support
rusulh
in reply to: bob_holland
Hey,
I'm running the trial version or inventor, I have been using it heavily for the last 5 days and used the bolted connection tool many times. All of a sudden today I am having the same problem in the subject line - the dialog box simply wont appear. I get the prompts to select the face, hole and termination point but there is no dialog bog present anywhere.
