Hi All.
I have been working on a large assembly and I am trying to get a bolted connection to pass through a component and a machined plate. I have been using the cocentric option to complete many other holes up to this point, but not through a machined surface.
When I attempt this, I get two errors saying:
Design Accelerator Doctor
1. Failed to add sketch for a hole
2. Failed to create a hole
My questions are:
Is there a way around this Or is this a problem that I am going to have to work around?
Or
Is there a better way to get a hole/bolt through this assembly?
Thanks!
I don't think it will be possible to answer this question without a dataset.
Make up a simple example assembly and attach it here.
