I've got the same problem with Inventor 2013 SP2. When using the "Follow pattern" all the bolts created using the same "Bolted Connection" can rotate around the axis of the first bolt.
I'm using the 2018 version and still facing the same problem.
Sometimes, the bolted connection is moved accidentally and when the manufacturing drawing is made, the hole ends up in the wrong location. Very expensive mistakes!
Autodesk! please suggest a solution!
Hi Guys,
The behavior sounds defective. Could you share an example?
Many thanks!
Hi Nick,
Many thanks for sharing the files and video! Indeed, this is a limitation in Bolted Connection workflow. The concentric option does not seem to apply the appropriate constraint unfortunately. I have heard about this request before but it does not look like we have a good solution yet unfortunately.
