Hi all,
Hate to dig up this old thread, but I'm having this problem again... I've got 2 styles of washers I would like to use in Bolted Connections, but only one style appears in the dialogue box. I've tried all the suggestions I've found so far, but I'm not having any luck. I even tried making a copy of the family that was working, but the copied family didn't work.
Has anyone got any suggestions??
Im having a similar problem.
Ive authoured a bolt, nut and washer into content centre (used bolt nut and washer from existing content that works in the BCgen)
I can add the bolt and the washer, however, the nut will not show up in the selection box.
People are discussing on this and other threads about the filters using thread type and size.
However they do not indicate how inventor 'sees' the size and the type...is there a specific paramater that needs mapping, if so what is it?
Please can someone help me find my nuts ;D
extra attachment (could only attach 3 files to last post)
someone has to know how the CC and BC work.
Or does anyone have links to whitepapers or discusions on authoring CC parts for BC ???
Any help appreciated
Can you post a shot of the "General" tab under family properties of the missing fasteners? What do you have on that tab for Standard Organization?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I know this is an old thread, but has anyone found a solution? I have custom cc parts that work great but the nuts do not appear in the bolted connection generator. I know it's not an odd size, Im thinking its a cc issue. Ive followed several threads, but have not seen the solution. Autodesk?
What work flow did you use to create your custom nut parts? Did you copy an existing one to your custom library and modify? Would you be able to post screen shots of the family properties screens?
When you are trying to use these parts, have you already placed a bolt and washer?
Chris Benner
Check that your THREADDIA collumn in your table isn't filled with an expression. It has to be filled in manually, otherwise you'll get an error regarding the family table.
And of course, check if you're working in the right project where the custom library is declared, but that would be too obvious
In addition to this, also make sure that all collumns with expressions are no longer 'black' but expressed, in blue. This also could be a reason for not showing up in the Bolted Connection ...
