Hello everybody!
I need to find a way how to set a custom parameter to be equal with a body volume, assuming I have a multibody part.
I have found how to assign total volume of the part to a parameter using iLogic rule.:
Total_Volume = iProperties.Volume
and that's it.
You can do it also for a component in an assembly , but can't see how to do it for a body...
Please help!
Regards
Sandu
Solved by MjDeck. Go to Solution.
Hi! I could be wrong but I am not aware of body level volume in a part file. The physical properties are all evaluated on a per part basis, not per body basis.
The original design intent of Multi-Solid Body workflows is that each solid body would be derived as individual parts eventually. For your case, you should be able to query each body volume if the bodies are all derived into different parts. Can I ask you why you need to have body level volume?
Thanks!
Hi! I have to revert my prior statement. The body level physical properties can be found if you right-click on Body node -> Properties in the browser. However, the parameters associated with these properties are not exposed to the user. I need to find out why or how. I will get back to you with my findings.
I am very sorry for the misinformation I posted earlier.
Thanks!
The point is that you can see each solid(body) volume in its properties. See the attached screen capture.
The main ideea is to make a container (one body) with product volume as separate solid (second body). Then I want this to publish to Content Center.
When inserting the part (container), the custom parameter will be the volume. Depending on the volume, the height of the container will be calculated by Inventor. This will be possible with an iLogic rule. I made it for a single body part.
If only it would be possible to publish assemblies to Content Center... but no way...
Update: I just saw your last replay on that. Thanks for looking at that.
SolidBodies.zip has a rule to calculate the volume of a solid body. It has a few other functions for solids. It can be used as an external rule, but for a content center part it might be best to put it in the part. You can add a rule (name it SolidFunctions) and paste in the text. Set the Straight VB Code option on the Options tab:
Then create another rule for your code. Here's a sample. This is in a part with bodies named ContentsBody and ContainerBody.
AddVbRule "SolidFunctions"
Dim bodies As New SolidBodies(ThisDoc.Document)
ContentsVolume = bodies.Body("ContentsBody").Volume
ContainerVolume = bodies.Body("ContainerBody").Volume
Note that this rule won't run automatically when the volume changes. You can add lines that refer to model parameters to make it run:
trigger = d0 + d1 + PartLength ' etc.
Or you can use the Event Triggers command and set it to run on the Before Save Document event.
That's just brilliant! Thanks a bunch!
But what are the other functions of this SolidBodies.vb rule? Just beeing curious 🙂
Regards
It looks like I need a little bit more help to reach my main goal.
I want a rule that changes a parameter until 2 parameters are equal.
Let me explain you this way:
If Volume1<>ProductVolume Then
d12=choose a value until Volume1=ProductVolume
End If
I suppose it should be simple, but I struggle a lot with programming...
Thanks!
hey did you find a good solution?
I have the same problem with digger buckets one solide is the SAE volume and the rest is the bucket body.
the set up i have now is to change a dimension some times until i reatch the desired volume.
I would like a rule that would drive that parameter based on the volume of solid1
Hi
I followed your instructions on how to implement the code - no luck so far.
I dont have alot of experience with ilogic - but what I would like to accomplish is the following.
I want to write the specific volumes of multibodies into the parameters, to use for further caculations. As I understood your code should get this done.
Would be great if you or anybody else could give me a hint how to get this done
Greetings
Alex
@Anonymous , the code you have should work with a few changes.
First, change the line:
AddVbRule "SolidBody"
to
That's the rule name you're showing in the iLogic Browser. I'm guessing that it contains the same code as SolidBody.vb posted above. If it doesn't, please post your part (or a simplified version).
Then, create User parameters in the part and name them Volume_1 and Volume_2. Give them units of volume.
Then edit the rule. Just hit Save and Run. That will connect the rule to the parameters.
Here's your rule for reference:
AddVbRule "SolidFunctions" Dim bodies As New SolidBodies(ThisDoc.Document) Volume_1 = bodies.Body("1").Volume Volume_2 = bodies.Body("2").Volume
Thanks MjDeck,
for the quick reply - I did implement the changes, however no functionallity yet?
Please have a look at the posted part - it would be great if you could tell me what I am missing to make it work.
Many thanks for your help
Alex
@Anonymous , your Call rule has the "Straight VB code" option set (on the Options tab) in the rule editor. The Call rule is not straight VB. Please un-check that option.
The iLogic system might have set that option itself. This is a defect. If you use Straight VB rules elsewhere, please keep an eye on this option.
Fakeru,
I get this error in your iLogic rule. Any idea how to solve it?
Kind regards,
Wesley
@w_landkoer , the code in SolidBodies.vb won't run as a rule by itself. It contains functions that you can use from another rule. There are some examples above. What are you trying to do?
Dear @MjDeck , Dear Gents,
Thanks a lot for SolidBodies rule and all advice. Thanks to this I am able to got mass of each body in my part.
However, i still need to get X-Center of Gravity of each body, Is it possible to get this using SolidBodies rule ?
If yes, could You please advise me how to that ? I will be grateful.
Best, Maciej G
Hello @Maciej.GorskiL3SPU - you can do it if you are using Inventor 2023 or later. You can get the center of mass from the MassProperties property on the SurfaceBody object.
Unfortunately, currently I use Inventor 2021 and that's why i'm looking for help here. Anyway, thanks for Your quick reply
Maciej
In Inventor 2021, you could do it by creating a temporary part (only in memory: no need to save). In the temp part, derive the one solid from the original part. Get the center of mass of the temp part, then close it.
