Hi everybody,
i am using invertor 2014 professional,
my computer dell t5500
16 gb ram
quadro 4000 graphic cards
dual cpu xeon e5645
making chicken and poultry equipments drawing,
I'm having a hard time sometimes in turn projects and waiting time
i want best performance for inventor
part in the program and the graphics card settings are the best possible performance.
direcxt or open gl whichever works better.
I would ask them to help on the subject.
Main suggestion is to increase your RAM from 16GB to 32GB or more however some main boards and/or computer manufactures will only accept/allow a maximum 16GB at the most, Dell may be one of them, check with you handbook on-line manufactures specs to see if you can add more than 16GB
Secondly defrag your HDs
Thirdly, a bit complex, increase your Virtual memory minimum to be doubled (32768) and the maximum to be 4 times (65536) to whats in your system now
a) Start Control Panel
b) select Systems
c) from the inside select Advanced System Settings
d) Advanced Tab, if not already selected
e) Click on Settings
f) Click on the Advanced Tab
G) Click on Change
h) Make the suggested changes, click on Set, click OK to any prompts, then OK until you out of the Advanced Settings
YOU MAY HAVE TO REBOOT YOU COMPUTER FOR THESE SETTINGS TO CORRECTLY TAKE EFFECT
Fourthly only have open the minim number of programs need, each one even though not in use shells out bit of RAM therefore reducing what you have available.
yor processor is too slow...
get the fastes i7 (4790) and it will boost everything....also SSD would help
richard
thnx for answers,
shortly, my pc is fast windows applications
inventor open is fast
file location pack and go or network data
my network is 1gigabit
total data size 182 MB
i am using 534 part and 81 assembly files in my document,
orbit or change part is poor, sometime hesitation,
i change virtual memory size is good windows settings best performance
For the best performance out of them is what we do
again thnx for everything.
my english is not very good sorry.
I did see many many times HUGE performance difference between 2.4GHz xeon and 3.3 GHz xeon systems (same VGA, RAM size) - for opening drawings, making changes, etc....
I am really trying to help here but if many "well experienced" guys say it does not matter...no comment...
get the fastes i7 available with SSD and you will be surprised....
ALL based on personal experience over 10 years.....
Richard
Most of the time such observations are done with an old computer thats been in service for some time vs. a brand-new computer, so the differences are more likely to be between accumulated services, legacy installs, and so on rather than the different hardware.
