Inventor Forum
Bend
11 REPLIES 11
Message 1 of 12
BeKirra
611 Views, 11 Replies
Bend
I Bend a 100x100 square plate by using "emboos" command.
I am wondering that if this can be done by using "bend" or other command in sheet metal mode.
I have tried without success.
The bend radius = 500mm
The plate should be bent symmetrically along the center line.
Please see the attachment.
Your helps are much appreciated.
I use inventor 2014.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
11 REPLIES 11
Message 2 of 12
CCarreiras
in reply to: BeKirra
Hi!
The plate has 100x100 when is folded, or in flat pattern?
Did you find this reply helpful ? If so, use the  Mark Solutions!  Accept as Solution or Give Kudos!Kudos - Thank you!
CCarreiras
Message 3 of 12
CCarreiras
Hi!
Yes, it's possible and it's simple. Check it, file in attach.
Questions:
Thickness?
Round radius?
100x100 flaten or folded?
inside or outside the 500 radius?
CCarreiras
Message 4 of 12
BeKirra
in reply to: CCarreiras
The plate is flat and I want to bend or "fold" it.
The one shown in the screenshot was created by using "emboss" command.
How to create the bend in sheet metal? Thanks.
X² + Y² = C²
Message 5 of 12
BeKirra
Thanks for your help.
You're right. I need to give more info:
Plate size: 100x100mm (flat)
Plate thickness: 2mm
Inside fold radius: 500mm
The round corner details can be ignored.
The width of your model is 101.76mm when it is flattened.
How to create the model based on a 100x100 flat plate?
X² + Y² = C²
Message 6 of 12
CCarreiras
Hi!
We can achieve that with a little of "inverse engenearing" Smiley Happy
Check it.
CCarreiras
Message 7 of 12
BeKirra
Thanks again.
The flat pattern looks good.
But the folded model is not folded in the center line (symmetrical line).
I tried to fix the "cut" in your model but it caused the feature "Refold1" failed.
X² + Y² = C²
Message 8 of 12
CCarreiras
Hi!
Post the file you edit and will see it.
CCarreiras
Message 9 of 12
BeKirra
Thanks for your time.
I turn on the center line so you know what I mean.
X² + Y² = C²
Message 10 of 12
CCarreiras
Hi!
Ok, i understand why it give a error when you try to refolding, that's because you delete unfolding reference plane (the one you chose to unfold).
I don't get why you need to have the part centered, but ok, no problem. I solve this also with a slightly new approach.
Check it!
CCarreiras
Message 11 of 12
BeKirra
Thanks again.
I now see your idea. I appreciate what you've done.
It is weird when Inventor doesn't provide a simple function that allows the fold to be centered.
X² + Y² = C²
Message 12 of 12
CCarreiras
Hi!
I supose this part is a cover to a big cylinder, rigth?
If you have the cilinder first, you can always import the faces of the cilinder (derive),
or
design this plate in the assembly enviroment.... and you will have a "easy" way to have your part centered.
But i can agree that is a little advance methods and a little out of the "traditional" modeling, but its possible to do it... after all, we do it!! Smiley Happy
Glad to help you, Cheers.
CCarreiras
