Inventor Forum
Bend Note Rule - Ilogic replace
3 REPLIES 3
celesiob
892 Views, 3 Replies
Hello, does anyone know any rule to replace the annotation direction bending, as attached image, I thank all who help.
3 REPLIES 3
theo.bot
in reply to: celesiob
Try this:
'loop tru all bend notes
For Each oBendnote In ThisDoc.Document.ActiveSheet.DrawingNotes.bendnotes
'clear previus text overrides
oBendnote.text=""
oBendnote.hidevalue=False
         'check direction and set note
         If oBendnote.text.Contains("DOWN") Then
         otext= Replace (oBendnote.text,"DOWN","BAIXO")
         oBendnote.text= otext
         oBendnote.hidevalue=True
         ElseIf oBendnote.text.Contains("UP") Then
         otext= Replace (oBendnote.text,"UP","CIMA")
         oBendnote.text=otext
Next
don't forget to set a event trigger to run this rule for updating your notes, because now it's a text override.
succesSmiley Happy
tony.yates
in reply to: theo.bot
Hi Do you know how to get the bendnote to show with ilogic ?  without having to select the line.first.
Cheers,
