Inventor Forum
Basic Issue - About frame and sketch
15 REPLIES 15
Message 1 of 16
882 Views, 15 Replies
Hi..
I have a basic question.
When i make a frame ( ex. a  C - profile ) and i want , on the top of the profile to weld a round steel bar do 10mm of diameter.
putting the profile is easy. and when i close the enviroment of the frames.. and open a 3d sketch.... i draw the circle of 10mm   and after that i try to make an extrusion.. and i cannot do it... the inventor wont let me...
and its a basic thing...  make a circle and extrude... but on 3d sketch after closing the frame generator... it wont let me do it...
Help please...
Thx
15 REPLIES 15
Message 2 of 16
blair
Can you post a picture of what you are trying to accomplish.
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 16
JDMather
A circle, by definition, is 2D.  Why use 3D sketch for 2D geometry?
Given that there is no Circle tool in the 3D sketch environment - how are you creating a circle?  By projection?
Message 4 of 16
in reply to: JDMather
Hello.. thx for help...
I will post a image
here is the link..
http://imgur.com/uUTrBE0
That is what i try to do with the extrude... i am sorry.. i make a mistake... i make in the 3d model option... and after that i choose 2D sketch..
Message 5 of 16
JDMather
@Anonymous wrote:
I will post a image
Why didn't you attach your image here?
Yes, your browser shows a 2D sketch at the assembly level (not part level and not 3D sketch as you indicated earlier).
If you had that assembly in front of you what could you do?
You could only cut from the existing assembly.
Notice that the Extrusion preview shows red (Cut function).
You need to either
1. Create the part separately and add the component to the assembly
or
2. Create the part in the context of the assembly.  (Create New Part)
Notice that in your browser below the sketch it says End of Features rather than End of Part.
This means end of Assembly features (which can only be cuts to the existing assembly).
Message 6 of 16
ok.. thx for the tip...
i see i cannot make the draw in the general envoirement.. even if i choose to make a sketch...... it will not work only as you say with a assembly or creating a part...
Message 7 of 16
one question.. and if i want to center the steel rounded bar.. with the center of the profile ?? in the assembly i can do  it..  but centered..  i am not seeing very well....
Message 8 of 16
JDMather
Project Geometry from the edge of the part you want the bar centered to.
But since you are not experienced with top-down, in assembly context modeling - I recommend that you create the bar separately and then place in the assembly.  You can use the origin plane in the center of the frame member to Mate to the origin plane in the center of the bar.
This would be very easy to demonstrate if you attached your assembly here.
Message 9 of 16
ok.. here it goes the assembly.
 with the steel round bar too
Message 10 of 16
JDMather
An assembly file (*.iam) is only a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints (and a bit more).
You must include the part files.
Message 11 of 16
sorry... i was sleeping.. lololol...
Message 12 of 16
still 2 missing...
Message 13 of 16
JDMather
Is something like this what you are after?  (see attached)
Message 14 of 16
yes.. perfect.. how you do it , to center the round steel bar with the center of the frame ? using assembly  what commands  ? what tips... ?
thx
Message 15 of 16
JDMather
Add Mate - Flush (or Mate) between the YZ plane of the frame part and the YZ plane of the rod.
(don't have to make them visible like I did in this image - I only made them visible for clarity)
Message 16 of 16
thx for the explanation...  and its funny.. that i found another way to assembley that... i use the join function... and worked as well 🙂
Thx again...
