Inventor General Discussion
Valued Contributor
albmopar
Message 1 of 10 (323 Views)
Accepted Solution
Ballooning in I assembly
323 Views, 9 Replies
08-28-2013 01:51 PM
I have several iterations of an assembly.  Specifically I have a base of a machine with different tooling for different products.  I generated the BOM by referencing the specific tooling I am trying to detail.  That worked.  But when I balloon, it references the main assemlby.  It won't let me redirect the source file to the tooling asm
*Expert Elite*
Cadmanto
Message 2 of 10 (320 Views)
Re: Ballooning in I assembly
08-28-2013 01:58 PM in reply to: albmopar
If you want to show the components the tooling assembly in your upper level assembly, what you need to do is in the tooling assembly go to the "Tools" tab
and make sure tis assembly is set to "Reference"
What this will do is show the components of this assembly in every assembly it is inserted into and not show the sub-assembly number.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! :smileyvery-happy:
Best Regards,
Scott McFadden
Inventor Professional 2013
(Colossians 3:23-25)
Valued Contributor
albmopar
Message 3 of 10 (313 Views)
08-28-2013 02:07 PM in reply to: Cadmanto
I got the refence thing down, but even though the BOM is tied to the sub assembly, the balloons are tied to the main assy.  So the only balloon I get is 19.
*Expert Elite*
Cadmanto
Message 4 of 10 (259 Views)
09-23-2013 07:17 AM in reply to: albmopar
The parts list should be tierd to the main assembly showing the components of the subassembly allowing you to balloon the subcomponents.  If this is not happening that you need to check the ststus of the subcomponents to make sure they are not tagged "Reference" as well.
Best Regards,
Scott McFadden
Valued Contributor
albmopar
Message 5 of 10 (241 Views)
09-23-2013 08:57 AM in reply to: Cadmanto
I don't get the option to balloon the subassembly when I select balloon.  The subassembly is set to Normal, not phantom.  Am I missing something?
*Expert Elite*
Cadmanto
Message 6 of 10 (235 Views)
09-23-2013 09:08 AM in reply to: albmopar
If you go to where I instructed you in my original posting, the sub-assembly should be "Reference" and all of its components should be "Normal".
Best Regards,
Scott McFadden
*Expert Elite*
mcgyvr
Message 7 of 10 (229 Views)
09-23-2013 09:43 AM in reply to: Cadmanto
Its phantom not reference..
Down with IDW/DWG files..... Long live 3D PMI... Hurry it up already..
2015 Product Design Suite Ultimate
Windows 7 64 bit
Core i7 4820k processor (OC'd to 4.4Ghz), Nvidia GTX 770, 16G RAM
Valued Contributor
albmopar
Message 8 of 10 (222 Views)
09-23-2013 10:05 AM in reply to: mcgyvr
The subassembly is the one I am trying to balloon.  The sub assembly is changeover fixturing on a peener.  I have the peener set to reference and the fixturing set to Normal.  As shown in the BOM, I can choose the fixturing to fill out the BOM, but only have the option to balloon the whole assemlby, which only shows item 19, the fixturing.
*Expert Elite*
Cadmanto
Message 9 of 10 (211 Views)
09-23-2013 10:54 AM in reply to: albmopar
I mistyped before.  Mcgyvr is correct.  The sub-assembly should be phantom and its components should be normal.
If you do this, this sub-assembly should be able to be ballooned in the top level assembly.
Best Regards,
Scott McFadden
Valued Contributor
albmopar
Message 10 of 10 (201 Views)
09-23-2013 11:23 AM in reply to: Cadmanto
AH-HA  Thanks too all.
Announcements
Need installation help?
