I have an assembly made, but its to be welded and I did not want to change it to a weldment for simplicity within the drawing environment. But anyway; I have 4 parts in the assembly, and in the parts list I added a custom part for the weld material.
Now I also added the weld annotations in their correct locations, but I was wondering if there was a way to add a balloon to the weld symbol. In the little note section behind the weld symbol, I would put a floating balloon which would specify the material of the weld.
This was done on older drawings in autocad, but inventor wants me to tie the balloon to a part so I cant really figure this out.
Can anyone help?
You can add the balloon and just overwrite the item number with whatever you want.
Or in the styles editor create a specific balloon type/style and use this for only these type cases.
Hope this makes sense.
HI vsookrah,
I addition to the previous suggestion you can select the custom part by following these clicks:
I hope this helps.
Curtis
I guess I wasnt clear in my original description.
I know how to do the custom part ballooning, but I'd like to create a detattched balloon. Just a simple balloon with no leader, but I dont have an option to do that.
Is this even possible
HI vsookrah,
The only thing I can think of would be a custom Sketched Symbol with a prompted entry, into which you'd add the custom part information. It wouldn't be tied to the BOM though.
I hope this helps.
Curtis
I don't think that is possible. Seeing the balloon wants association to a part through the BOM.
What I am thinking is you can do this if you have a block created in ACAD just insert it into your Inventor drawing.
