See files. 2014 and 2013 show the same issue.
Workpoints placed on part are ok, but 3 additional points placed in IAM are not. It's not only a graphics issue, distance measurements to the yellow face are different, too.
Walter
Walter Holzwarth
Solved by johnsonshiue. Go to Solution.
Hi! Walter, this is a great catch! The behavior is not right. It looks like the mid point location on this intersection edge recorded by the assembly constraint (attaching the assembly workpoint) is slightly off from its actual location. I am sending it to development for further investigation.
Many thanks!
Thanks, Johnson. No real solution is in sight for this at the moment, but I'll change the color ..
Walter Holzwarth
